“Skip this Run” not showing up
Hey @MichaelD
It is true that you cannot use the “Skip this run” feature across multiple days, I believe our “Delay Water” feature will solve your need to skip watering for three days while contractors perform work in your yard.
You can access the “Delay Water” feature by navigating to the “Irrigation” tab, select “Calendar” at the top of the screen, then select “Delay Water” at the bottom of the “Calendar” screen. Now, you can delay all scheduled watering events for up to 7 days. If you choose three days, the watering delay will expire automatically after 3 calendar days have passed. You can also cancel the delay at anytime through the “Delay Water” banner at the top of the screen by selecting “RESUME”
