Let’s say for a month I want to water manually by starting from the App so I go in and disable the schedule. Is there a way to still see the moisture level on the “zones” tab because it disappears as soon as I do that?
@terminator You should be able to set a schedule End Date in the past. This will stop the schedule from running and still give you soil mositure, but please don’t forget that you did this
Perfect. I think that worked.
@timber I was going to stay its not possible since we don’t show zone moisture if the schedule is disabled, I love this hack.
