OK, I need some help. I have installed my Rachio, and even had my irrigation person modify it to be better aligned to my yard. But it is still doing some things I cannot figure out.
- After well over a month, I have had Zero weather skips (at least per the stats). Now the only reason I can figure this is the case may be because I have a water sensor attached and that is causing the skips?
- When I look at my schedule, it shows that it is going to skip 6/14 through 6/16, and then water every day from 6/17 until 6/28. Why would it schedule almost two weeks straight of watering??
