Not sure what this means - I’m trying to skip watering through the API. I have the bearer and schedule rule ID. when I do the PUT and pass the ID I get a return code of 900 that says ‘not supported for 3.0 API’
Is there a different way to stop watering for a day?
Ideally I would be able to do it by calendar day and skip ‘all zones’. I don’t there is support for that manually, so I was going to just skip each schedule rule through the API on given days.
Where are you passing in the bearer? It typically goes on the “Authorization” tab and when you do, it usually has a green dot by it like we see with “Body”.
I appreciate the feedback. removing the comment does not help.
In the authorization tab the bearer is inherited. This is for the whole collection. I use this same collection to get the person id, device id, zones, etc. I’m confident it is not the bearer.
I have other PUT functions working - i can start zones and stop zones no problem. Passing the Zone ID through the body in JSON works with the inherited bearer.
Stilll just goet this ‘not supported in v 3.0’ errors.
I decided to try another schedule. Everything seems to be correct, just like you, and I get the same results as you. Seems to be some issue beyond us (documentation, API, whatever) unless we both made the same mistake.
