Hi! It is recommended to use a Fixed schedule if you’re under serious water restrictions (I expect this is the case?). Restrictions like this, twice a week watering, throws Flex into chaos since it needs the Flexibility to water on a range of days based on an evapotranspiration/soil moisture model it uses. Fixed schedules have plenty of smarts! The Rachio Support page recommends not using Flex if you can’t water more than 4 days a week:
Perhaps someone else on the forums has figured out a way to work with this kind of water restriction — one of the more severe forms is twice a week watering and I don’t know what lawn can stay green at 100 degree temperatures and so few watering (would likely go dormant? Hopefully). What kind of plants are in this zone/schedule?
@JGraff, @Kubisuro brings up all great points. Like he mentioned with your watering restrictions it is recommend to have a fixed schedule. You will still benefit from the weather intelligence (WI) features and it will guarantee to water on your two restricted days (unless WI skips it for precipitation or temperature)
Thanks @Kubisuro@franz. It’s is strict water restrictions. We’re allowed to hose water on off days which is only way to keep grass alive that’s in direct sun.
