since this post got no traction, I looked for a solution again.
Only notification I can use to go in my Home Asistant automation system is via Rachio Email.
only problem i get a lot of email, I can easily miss some. I have to send this info somewhere where I have a dashboard I can look at everyday for status. Rachio Home assistant integration does not have Flow meter info, so I have to do something manual.
The email from rachio as long as subject doesn’t change much, I can use it. with the following rules.
when Flow meter looses connection they send
subject: “The Flow Meter lost connection to your Rachio controller.” without double quotes
when Flow meter reconnects they send
subject: “Your Flow Meter is reconnected.”
IFTTT no longer has privileges to your gmail account to create rules from Email, with Subject String.
but in GMAIL Settings you can setup a forwarding rule in “Forwarding and POP/IMAP” tab
click on “Add a forwarding address”
i have ATT for mobile service. so my forward address for mail to text is
##########@txt.att.net
in Tip: below “Add a forwarding address”
I clicked a link “creating a filter” I created 2 filters to forward my mobile email address
my rules/filters are from: info@rachio.com subject: The …
Forward checkbox checked with address ##########@txt.att.net
1 filter for lost connection, 1 filter for reconnected.
in IFTTT i created 2 applets
for reconnecting
if New Android SMS received matches search
Keyword or simple phrase -> Your FLow Meter is reconnected
Make a web request HA URL-> https://yourdomainname/api/webhook/YOUR_API_KEY, method post, Content Type application/json
body
{ “action”: “call_service”, “service”: “script.turn_on”, “entity_id”: “script.set_flow_meter_connected” }
for disconnecting
Keyword or simple phrase -> The Flow Meter lost connection to your Rachio controller.
body
{ “action”: “call_service”, “service”: “script.turn_on”, “entity_id”: “script.set_flow_meter_disconnected” }
In Home assistant I have input_boolean for flowmeter that is set to true for connected set to false for disconnected by the 2 script i’ve created. there is also additional iftt setup in home assistant in automation.yaml for Home assistant to listen to the webhook URL call.
Maybe this will be useful to someone else.
/Pierre
