Setting up my Gen 1 unit I was able to connect to wifi without any problem, the only problem I had is my Iphone 5 phone died right when the setup wizard started. Phone is now fully charged, but can not restart the wizard. Looked everywhere on line trying to get the wizard to start again. Any Help please.
Thanks,
John
In the app you can add a new controller, should get you back to where you want to be
@jsattmann, if you are using the iPhone app - scroll to the bottom and tap on set up zones, you can re-run the setup wizard
