Hi All,
This is my first time dealing with sprinklers so I just wanted to make sure I’m connecting the wires correctly. I currently have Hunter Pro-C with a rain sensor connected to it.
So far, after reading through the forums, it seems that I won’t need the AC1, AC2 and the GND wires since the Rachio comes with it’s own power adapter. Am I correct in assuming so?
I have six zones with white wires and they would go through 1-6 on the Rachio. The red COM wire would plug into one of the C.
Finally, I am a little confused with the rain sensor, the two red SEN on the HUNTER… would one go into S1 and the other into 24 VAC -? Does it matter which one plugs into which?
Any help with be greatly appreciated. Thank you so much in advance.
Sam.
