I have a Rainbird Wireless Rain Sensor hooked up to a gen1 Rachio. It is pouring here in South Jersey and the rain sensor has not sent any notifications it has been activated yet.
Just curious as to what I should be looking at here from a troubleshooting perspective…
@canons900 You will continue to see scheduled waterings, but there is a check before the schedule that will recognize the activated rain sensor. The Device Updates section is near the bottom on the web app dashboard underneath your usage tile!
I checked the device and the screen on the unit is blank like it’s not getting power. Could this be the battery in the sensor? Or could it be the unit has died or failed in some fashion?
The sensor worked fine last year, the system is running, but according to the faqs, a blank LCD means the unit is not getting power. Is this a Rachio fault then or a fault in the rain sensor? Any way to check the device if I disconnect it from the controller?
It could be either. Rachio provides power to that sensor via the sensor ports.you could check the connections to see if they have a good connection.
To see if the sensor is bad and not the power ports for the sensor, you could plug the power into the mv socket, the other 2 into the common and enable the pump really setting then run any zone to see if the sensor lights up.
