Hi, I’m trying to use Rachio Gen 2 in Europe, everything seems to be ok but I can’t start up the pump. Where should I connect the pump cable in my new Rachio?
Kind regards.
Kind regards.
@Ozetoni1 - a pump start relay can be attached to the MV terminal. The Rachio unit can’t directly power a pump. Also, the master valve/pump start relay will need to be activated in the application for the Rachio to send power out that terminal and turn on the pump.
Thank you.
