Hello I was curious if the hub would support external 5v moisture sensors? If I powered on my own, or used a buck converter and stepped down the 24v to 5v, could I plug in my own moisture meter into the rachio hub?
Based on this: https://support.rachio.com/hc/en-us/articles/115010379227-Toro-Soil-Sensor, it appears you provide 2 inputs in the hub?
If it could read this data, would the API expose it in any way?
