Hi,
Suddenly Rachio stopped working. I am using Rachio 3 -8 zone for 1 week and it worked fine ,but now for some reason it stopped working. I removed and reset everything but still no use. Need help in fixing .
Hi,
Was the water cut off? Check the main cut off valve. Can you manually run a station from the valve by turning the solenoid or bleed screw?
