Rachio 3 not watering but zones running per the app
Not surewhat I’m doing wrong here … I’m replacing my rainbird controller with Rachio… did all the wiring correctly but when I run the schedule the sprinklers aren’t responding
Please see the pics below…Any advice would be greatly appreciated
Looks about right. It does look like you had 9 zones and now have 10. I would do the following and check running again, one at a time:
  1. turning off the rain sensor in your app (maybe also disconnect)
  2. manually (by hand, probably turn the solenoid) open master valve (or do you have a pump?) and turn on (through the app) a zone
  3. manually open the master and manually open a zone
  4. turn on a zone and manually open a zone valve
Did you try running the Rainbird just before switching it over?
