I have two Rachio 3s, 8 zone and 16 zone, and I use Eero mesh network of Eero 6 and Eero 7 routers, After the Ero firmware update 17.7.1, my controllers are going up and down. Eero provided another firmware update 17.7.2 yet my controllers continue their up/down behavior of going offline. All my other smart devices are just fine. Please help.
With 2 routers, is it clear who’s in charge? Might you be seeing a “double NAT” problem - confusion between two active routers advertising the same ID or capabilities?
Good question, this is a mesh network, it worked fine before the latest upgrade.
You’re not alone with this - since the recent eero firmware updates there are multiple reports of IoT devices (thermostats, Hue bridges, irrigation controllers) that stay connected to WiFi but lose internet on the main network, while the same devices work fine on the eero guest network. A practical workaround worth trying: put both controllers on the guest network - the guest band is 2.4 GHz, which fits the Rachio requirement (Rachio’s router-compatibility article calls for a steady 2.4 GHz WPA/WPA2 connection). If you need to re-onboard a controller, the eero app has a path under Settings > Troubleshooting > My Device Won’t Connect that temporarily pauses 5 GHz, which has helped others get Rachio units paired. Only a hypothesis that the guest network sidesteps your up/down behavior too, but it’s a quick test - and worth reporting to eero support either way, since a second firmware bump clearly didn’t fix it.
