Since setting up my Rachio, I have not been able to receive any push or email notifications. All alerts are turned on in the settings menu. Push alerts are on under the settings menu of my iPhone.
Under the history menu, I can see that a cycle ran and the rain sensor turned on. But I do not get any notifications of this being pushed. What am I doing wrong?
Hi @UroGator, are you still having trouble with your notifications?
There are certain instances where an app that has push capabilities stops leveraging Apple’s Push Notification Services (APNS). This can happen for a few different reasons. But there’s no error correcting for this process and so occasionally, you’ll want to reset the app back to what amounts to a factory default status, in order to get Push working again. The first time an app is opened, it will register for push notifications and prompt for receiving push notifications for the app. This prompt never occurs again unless the app is uninstalled for a minimum of a day and then reinstalled. You can duplicate this functionality by simply deleting the app and then installing the app again after setting the Date & Time manually a day ahead of the current date.
You would do this by:
Tap on the app and hold it until the the apps display an X.
Tap the X to delete the app from your device.
Turn the iOS device off completely.
Turn the iOS device back on.
Open the Settings app.
Tap on General.
Tap on Date & Time.
Move the date ahead a day or more.
Close the Date & Time Preferences.
Turn the device off completely again and turn it back on.
I have the App set up on 3 devices, iPad and 2 iPhones and am only receiving notifications on the ipad, the 1st device I installed on. I tried the delete/advance date on my iPhone XR as suggested and it did restore notifications for a day but then they stopped again. I’m thinking the problem is trying to push to multiple devices. My iPad continues to get notifications as expected. Clearly something going on.
