what API call from https://rachio.readme.io/v1.0/docs should be used to determine which zone(s) if any are currently watering and for how long? this could be either due to a scheduled watering or a manual command via the app.
what API all can be used to tell a particular zone to stop watering? i see a device stop_water, but not a zone stop_water. i tried using zone start of zero, which does stop the current watering, but then starts a zero length watering (that promptly stops). that seems rather inelegant.
thank you!
