My old Orbit controller is wired for direct power. How can I switch to a 4 zone Rachio 3 with the power supply they provide with a power block? I have no power outlets in the area of my current controller. My old controller is outside, so I will need to also purchase the Weatherproof enclosure. Thanks!
Are you seeing that you have 120V connected directly to the old controller?
@Akstrat - The Rachio outside enclosure is designed for direct power. Connect the direct power 120 V AC to the enclosure and there is a plug receptacle to plug in the Rachio power brick inside the weatherproof enclosure.
Great! I will look at the enclosures more closely.
