Hi,
I have Hunter SRC plus with 4 zone. I have an image attached. What are the cables I should hook up to the Rachio?
Your feedback is greatly appreciated.
Thank you
Hi,
Thank you
First off the two thick white wires going to the 24 VAC on the left ARE NOT needed on the Rachio. Follow them back and unplug the transformer that they are plugged into.
The two white wires on the C terminal go to C terminals on the Rachio. One can put them into the same or different C terminals - it doesn’t matter.
The zone wires in 1, 2, 3 and 4 go to the corresponding Rachio terminals (1, 2, 3, 4).
Welcome to the community and thanks for posting a picture - it made easy to provide the answer.
Hi,
Thank you for the clear insturction. Everything is up and running.
