Good evening.
I got my rachio gen 3 and got it installed.
I watched the YouTube videos and read the instructions.
Tested the system before the install to make sure it worked.
After installing and testing the zones.
No water is coming out on any of the zones.
Can someone please help me?
@reaxion - is the Master Valve option enabled in the app? If not, that is why water is not coming out.
Also, the sensor is wired incorrectly - I don’t think they’ll be triggered, but if they are that could also be a reason. Assuming the sensor is a basic hard wired rain sensor one wire will need to be in the 24 VAC - terminal and the other in one in either S1 or S2 and the appropriate setting turned on in the app for only the correct sensor port.
Do you remember turning off the manual valve? Upstream of your master valve, there is likely a manual shutoff valve, this would turn off the water supply to your irrigation valves and thus prevent anything from working.
