Please explain exactly how the Total watering inches in a zone is calculated
Thanks for the help. So basically I need to just put some cups out and get actual water rates then and I put that in the zone.
Anyone ever try to measure total GPM by watching your city meter while the zone is running and then calculate over the zone area?
One more question: since there are two zones that overlap, does it work correctly to set the rate at twice what it really is so it doesn’t double the water to the area because the two zones overlap completely?
