Hi there. My Rachio is online and connected. It’s stating through the app that it’s running as expected. But I’m not getting any water to run in four out of six zones (two are working).
@Thesing - check the wiring to those four zones. Is a multi-meter (volt/ohm) meter available for use?
Do all six zones use the same common wire going to the same sprinkler box or how is it set up?
Your questions spurred me to look at the wiring. And yes, the two zone that are working are powered by a different wire. I then realized I had one loose wire. Thank you!
Wahoo!!! I am so glad it was a loose wire which means it was relatively easy and cheap to fix. Good job!
