Hi. I just switched over from my IrrigationCaddy to the Rachio.
I brought each wire over from the IC to the Rachio one by one.
The power to the Rachio is provided by the power supply that was included.
Downloaded the app, created my account, and started the app.
The wizard all seemed to go fine, but when I went to test zones - nothing happened.
Any idea what I might have done wrong?
Thanks in advance.
https://drive.google.com/file/d/1lT1Us8Bj0M57ZcVDsJn73f_L_kz4_yx4/view?usp=sharing
I see seven zones ( 1-7 ) wires hooked up, but nothing going to common ( C ). Do you also have a picture of the original wiring?
I don’t. But those same seven wires were in the exact same position on the IC.
Couldn’t be more simple, so I transferred them over one by one.
There were no other wires into the IC other than power.
Sorry for maybe silly questions, do you in fact have seven zones? Any possibility you have six zones and one wire was connected to COM?
I found a manual (not sure if it is same as what you have) at http://cache-m2.smarthome.com/manuals/31168.pdf
Bingo. That was the issue. Tsk Tsk to me for not taking a picture of the IC first.
Thank you!
Glad you got it worked out and we were able to help.
