No no no (why are my flex zones 110% moisture?)
#9
@Dwiniger - that is one of the powerful features (IMHO) of Rachio. Rachio won’t water when it thinks rain will be coming within 24 hours. Once the forecast becomes reality, Rachio will update the zone details with what actually happened (e.g. more or less).
#10
Then the word Projected should be added to the saturation %.
Would explain everything.
split this topic #11
A post was split to a new topic: Flex daily moisture levels not correct
#12
I wonder about this too. With our monsoons and the extreme microclimate activity I wonder if using predicted rain can do more harm than good. Let’s say I was be due to water on Monday if there was no predicted or actual rain. Then I get predicted rain on Monday and each day of 5 the consecutive days afterward, and no rain actually falls on any of those days, which day of the week will my irrigation kick in? It’s a very real scenario in Phoenix this time of year.
#13
Same for Texas. :smile: There may be a 50% chance of rain in the region but the chance that it’ll actually rain in any one spot is far less. Most rain events this time of year are very scattered and sporadic. We had rain last week, first time in over three weeks. Our community Facebook page ad people posting rain gauge totals ranging from 1.5" all the way up to 3.5", all valid and all within one relatively small town.
In the northern midwest it seemed to rain over larger areas so the predictions were more reliable for a larger area.
#14
@helosix @azdavidr It’s a damned if you do, damned if you don’t problem. My favorite. Once your zone is fully depleted to 0% the hope is forecasted precip isn’t greater than your depth of water (bucket fill value) so we irrigate that day. We take precip intensity and percent of probability (POP, probability of rain) and multiply to get the forecasted precip. If POP is < 80% we multiply by precip intensity, if POP > 80% we take at face value (i.e. 100%).
.5 precip intensity, POP 50% = .25 precip forecast
.5 precip intensity, POP 85% = .5 precip forecast
For all of the variables we have to factor in, I think this method is fairly conservative, but clearly in different areas of the country works better than others.
If POP and precip intensity are always larger than your depth of water we won’t water. I’d say in those cases your depth of water might be too low since it’s hard to believe we would have forecasting > .4+ inches of precipitation every day. :confused:
Thanks for the explanation. It sounds like although unlikely, there a chance that predictions could have kept my lawn from getting irrigated all 5 days of my example?
Is there an option to turn off the use of predictions for a given zone? I just don’t think the advantage is worth the potential savings in our particular climate, whereas the risk is significant due to our extreme weather. I could see it working great in many areas, so it’s a nice option to have available in those places.
#16
Next time you experience this behavior I’d like to see the moisture graph, curious what the values are.
Not at the moment.
It was a hypothetical. I’ll let you know if anything comes up, but I’d honestly rather not monitor it that closely these days. When was use of predicted data introduced?
FWIW I’d like to see the option to disable it in a future release. I know there can be interdependecies that might make it more complex than it seems, but hopefully that’s not the case. I have some vegetation that didn’t fare as well this summer as last summer, and I wonder if this was a factor.
Should I override?
#18
I must have not worded this very well, or perhaps my suggestions were not well received by the community, but I have the same problem here in Charlotte. So far the most I have seen is 3 days with the moisture level at 0% without watering. I’ve never let it go further because I do a manual watering to keep the plants from dying. I don’t care quite as much with my grass as it can go dormant, but I really care with the rest of my landscaping.
See Need a way to handle precipitation that doesn't happen for Flex Daily
#19
@Linn - and @azdavidr - same here all four of my zones are at zero moisture from last night and no watering today I don’t know if it’s because flex daily is forecasting rain :cloud_with_rain: for tonight or I don’t know what’s going on I even get an error when trying to load moisture data on my iPad.
#20
My shrub zone reports 0% and I also can’t see my graphs.
This is really concerning to me. I pushed my tree and shrub zones to where they can’t afford not being watered when they get depleted . I’m becoming more certain this is the reason I’ve lost some shrubs that have been fine for two years on Flex.
Sorry @Linn, I just plain missed this. I agree with you 100%.
Again, when was the use of predicted rain introduced?
#21
Using forecasted precipitation has been a feature of flex daily since it was first released.
Can you provide forecasted precipitation pushing watering to the next day with 0% soil moisture screenshots? I’d like to get more familiar with the data to better understand the issue. Thanks!
We’re currently investigating an issue with moisture graphs being intermittently unavailable on the mobile app. In the meantime, they are available on the WebApp.
In your case @azdavidr, as we can observe with your Shrubs (Zone 4) this Zone was in fact expected to be at 0% (with a 50% AD) today:
It looks like your Shrub schedule is currently running.
#23
@Anthony, looking at your Zones we are receiving forecasted precipitation for the next 2 days that should sustain your lawn until 8/21 when your next Flex watering is scheduled for:
#24
Thanks @franz. I wonder if predictions vs. actual this summer was different enough this summer to see a potential impact. I don’t recall seeing skips due to predicted rain prior to late spring of this year.
Thanks for checking on my shrub zone today @mitchell.
#25
Most people in Charlotte (and other cities) have their advance setting on their zones’ settings not set right. Make sure your root depth for grass is set for 3" by default the controller sets cool season grass to 6" and warm season grass,to 9". No where in Charlotte do people have more than 3" of grass root depth. Most shrubs are 6" at must. We have very hard clay based soils. Also check you get a very close weather station and install a rain sensor on the controller too.
#26
Thanks for the input — my grass is fine, it’s my perennials and annuals that are my biggest concerns. Yes, a close weather station is the best for getting the nearest to what my actual rainfall was. The rain sensor is just a good double check to keep from watering if I got rain that the weather station didn’t get. But the rain sensor has nothing to do with this problem — the problem is that weather forecasts are for general areas and are best guesses. And the rain is spotty.
Also, surprisingly, not all of the Charlotte area is hard clay – According to the USDA Web Soil Survey Site, my soil is half CeD2 Cecil sandy clay loam and half EnB Enon sandy loam.
#27
You really can’t go by that soil website because many builders bring in soil (red clay) to build up areas before, during and after construction which changes the original soil conditions.
#28
Much better if Rachio came out with in ground moisture sensors … fixes lots of variables and assumptions.
