New user, initial setup, wants almost 4 hours to water
Aha - if every thing is new then the default root depths won’t work well. The root depth for all the types of crops will be much shallower and you will need to water more frequently until the plants are established. Ideally you want to set the root depth a bit deeper to encourage root growth. You can go into the advance settings of each zone and change the root depth or just change the time in the schedule.
I’m in Rhode Island so not nearly the same climate but water here is expensive especially if you use so much you go into the 2nd pricing tier. Always a trade off between how much you water and your water bill.
