With the new update today, I get this every time I open up the app and go to the moisture graph in iOS.
Coming across my macbook on Safari when I visited the web app for the first item since the update.
Viewing the moisture graph in iOS should no longer prompt you to share your location. The web app will prompt you for your location.
Let us know if you come across anything else…
Thanks,
Dan
Thanks @Dan . Does using my location on the webapp mean that if I travel, Rachio will think I’m in a different time zone and adjust based off that? Or is my location of my Rachio unit set and is not influenced by my macbook’s location.
The location of your Rachio unit is set and your current location will not affect that
Thanks,
Dan
