NEW Dynamic Crop Coefficient feature
Rachio definitely has a bug with the new dynamic crop coefficient. I have been seeing different durations among my 7 zones even though all settings are the exact same.
Today I deleted the flex daily schedule and did fixed schedule. I turned off dynamic crop coefficient, and set the crop coefficient on one zone to some other value. So all zones are on let’s say 70 (or whatever it is when you turn dynamic off) set one zone to 92 and save. You will see all zones have the same duration except for the one zone with a 92 crop coefficient.
Now turn dynamic back on and all zones have all different times, even though dynamic crop value is the same among all zones.
@drew_thayer I think I figured out what I’ve been talking about where the zone durations are varying among zones despite all settings being the same.
See screenshots in order:
Dynamic crop off, set to static.
Z4 set static 92
Z5 set static 78
Turn on dynamic for all zones and apply
Durations all vary even though all zone settings are now the same. All zones are set to dynamic 92 crop coefficient
While information on exactly how Dynamic Crop Coefficient works is sparse, with Flex Daily it should not change the watering time for any zone, just as changing the crop coefficient manually does not change the watering time. It will instead change when the system waters, sooner or later, to keep proper moisture in the zone.
I agree. But as indicated with my screenshots it’s alternating the times.
Are you able to create a mock schedule and test on your end? I was seeing this on flex daily and fixed schedule.
@Gerardv514 thanks for sharing these specific screenshots; these will be helpful as I dig into what’s causing these runtime discrepancies. @rraisley is correct: changing the Kc value should only affect frequency in a Flex Daily schedule, not runtime.
Something to check – are you using, or have you made adjustments, to the Adaptive Watering beta feature? (Only a small group of customers in a beta testing group has it – it has options on the zone page to “water a little more” or “water a little less”). We’re finding some interactions between that feature and DCC that can cause variance in schedules that otherwise should be identical. If you are using this feature, select “reset zone adjustments” at the bottom of advanced settings and see if that changes the runtimes.
I’ll have more next week, thanks for your patience. -Drew
@drew_thayer I’ve ruled this out since initially when I brought my issue up to you in the DM, I went ahead and did a reset on those to rule it out. I was still seeing this odd behavior so I then reset everything in settings and advanced settings. Still saw the behavior so did a factory reset on the Rachio 3. On a brand new fresh setup with very minimal changes (if any) I saw the behavior I described above. In fact everything was default when I created the screenshots above and I only touched the aforementioned values. That was how I was able to look specifically at what could be causing the issue. In other words I ruled out other setting changes that may have gotten stuck on the backend.
OK, thanks for approaching this methodically. I’ll get back to you when I have more to share.
@drew_thayer any update on any findings? I’ve gone back and turned dynamic crop back on, applied to all zones and I am not seeing the behavior I did when I first brought this up.
@Gerardv514 I have struggled to replicate what you were seeing on other devices, so I’m still a bit stumped. However, we released several small patch fixes in the past weeks since the main feature release, including another release this morning. It could be that your issue was solved by one of these minor logic bug fixes. Monitor for the next week or so and let me know if anything isn’t acting as expected.
I’m using dynamic coefficient for my northern California lawn and it’s getting absolutely destroyed by the 100’+ temperatures here. Browning grass everywhere!
I’d very much like to toss in a +1 for needing an offset to the dynamic coefficient, if I haven’t already.
How more innovated features are on the way for the Rachio!
As we cross the 2-year anniversary of the dynamic setting, please give some thought to adding an offset in future updates, if you haven’t already done so.
The FAQ states, “We did not design an offset into the initial release of this feature. If you want to use the recommended value plus or minus some offset, activate the feature on the 1st of the month, note the recommended value, then turn the feature off and select the value you want.”
Once you get soil settings and flow rate dialed in with all the great information in this community, crop coefficient seems to be the final frontier for dialing in frequency of watering in the flex schedule based on trial and error. Adding an offset would help leverage the wonderful automation of the dynamic setting while allowing the user to incorporate lessons learned in the field. Thank you!
Agree. The dynamic crop coefficient feature is useless without this. The values that the dynamic crop coefficient feature applies to my zones are so much lower than my previously chosen values that allowing the feature to choose those values would be devastating to my landscape, unless I completely rework all the other parameters.
Any plans to tweak this? Cool season grass should be around 94% in July, the dynamic setting is low to mid 80s causing brown stressed lawn.
Sadly can no longer trust the “dynamic” feature and went back to static.
Wish the company spent more time tweaking and fixing these settings in their algorithms instead of releasing new products like timers and lights :frowning:
@franz
An offset for this feature is definitely needed!
@franz
2 weeks since my post and silence. Can we get an answer as to if or when we can expect this feature / fix?
:flushed::roll_eyes:
