They are mandating I change my water schedule to only run every 5 days starting on the 10th, I cannot figure out how to make a schedule that goes every 5 days!
wow thanks for the quick answer! I did not realize you only see some options when creating a new schedule and not if changing an existing one.
I guess it depends what your existing schedule is.The intervals is only for fixed schedules. Once you have created a fixed schedule you can indeed go back into a fixed and change the intervals again. It is not only when you create a new schedule.
Ok thanks, I guess I meant it was not there on my existing fixed schedule. I understand I can change the new schedule. Again thanks for your help.
