Toro Moisture Sensors or any other sensors connected.
Allow each zone to be controlled/use/enable/disable a soil sensor.
If two sensors are installed (whatever type they may be) allow the zone to select which one it uses (A/B/A+B).
Current workflow has a sensor control the entire system.
Doesn’t seem appropriate to have one sensor decide if all 16 zones should be irrigated.
Thank you,
Jason
