Hi guys,
I currently have four zones in my backyard be ING feed of a water supply with a master valve in line.
I’ve decided to try install a fifth zone, however this zone is in our front yard and will be fed water from a different source. Ie the solenoid will be located in the front yard to an independent tap (ie not to the tap that is currently feeding the four zones and master valve at the back). Is the there a way to wire this fifth zone so that it doesn’t release the master valve at the back yard every time it goes on?
Cheers
