Sloped yard. Pressure boosting pump and relay wired to master valve. Need for uphill zones but not downhill.
- Can the master valve by zone be accomplished through a software update? or is a hardware upgrade required?
- IF possible by software update is this something Rachio developers are working on or planning?
Thanks in advance.
I asked about this last year also… I have a few large zones with higher flow heads that require a pump. However most of my yard doesn’t need the pump running and it just causes unnecessary wear and tear on everything by running at a higher pressure than needed.
Having zone based settings for the M lead would be an awesome feature.
Thanks
Michael
