I would like to see the ability to manually run a watering time at anytime. Now if I want to add a spot watering time I go in and change the start time and then change it back when finished. Maybe add that option to the long press which brings up edit or delete. Thanks.
Manually run a watering time
franz
#2
This is coming in our next release. You will be able to run watering times from the hourly view or watering times screen. A lot of other fun features coming as well. Our next release is all about user control
