After continuing to test and refine my Iro configuration, and with some zones not watered enough or too much before implementing my Iro, my Iro soil moisture related values were in many cases pretty far from what they should be. One zone showed to not flex water for about 1.5 weeks.
So I looked at how I could reset my Iro soil moisture related values, deciding that I’d just start over. Starting over is the only means I’m aware of at the present to reset any or all of one’s Iro soil moisture related accumulated values.
I couldn’t find a ‘delete zone’ function on the PC app (and I didn’t look on my Android app).
I couldn’t find a ‘delete Iro’ function on the PC app, but I did find it on the Android app. Knowing a little about how blink works, I thought it was a reasonable guess that I would not mess up the WiFi setting even with a ‘delete Iro’ from Android app.
So I deleted my Iro. Indeed I was correct that the Iro maintained it’s WiFi connection. I know what my Iro’s MAC address is, I can look up what it’s currectly assigned DHCP address is, and I can successfully ping it from the PC. (Plus the Iro’s WiFi status light is nicely flashing green.)
My problem is that using the PC, I can’t get anything more than a blank screen after logging in, and pretty high CPU usage as the PC seems to be sitting here, just spinning away, looking for something.
Using my Android Galaxy S4, after ignore the blink steps, I can’t get a connection to my WiFi network.
Anybody got any ideas on how I can get either the PC app or my Android apps to ‘talk’ to an already-connected-to-the-WiFi Iro?
Thank you.
Best regards,
Bill
