If you look in the activity feed all of your events show up there including rain sensor activated/de-activated.
If your weather station has recorded the precipitation and it is over the threshold set for the schedule, it will be skipped.
One hour before the schedule runs you will receive a notification in your events that says if the schedule will run or not based on observed/forecasted precipitation.
Please let us know if you have any other questions.
Ok - I seem to remember the least amount of rain that would trigger rain delay is .25inches - and it looks like I only got about a tenth, so that won’t set it off. And my rain sensor also didn’t trigger - so it must not be working.
Most rain sensors have a way to test. I would try that and make sure it is configured correctly. 1/10 inch or rain might not be enough to trigger since they also have thresholds.
If you do have any wiring questions [support@rachio.com] is a great resource.
