+1 for this request. I have citrus and avocados among many other trees in the grove. Avocados are particularly sensitive to heat, and they go from needing 1 hour of water time every two weeks in the winter, to 1 hour every two days in the heat waves of summer, every 4 or 5 days during normal summer heat. I don’'t want to let Rachio alter the duration because they need an oversoak to prevent the salts in the water from leaching too much into the surface roots and causing tip burn. 15 or 30 minute watering in the winter will be very bad for the avocados, other trees don’t care as much. If they don’t get this water duration and frequency they will drop their fruit and you lose a whole year of food. I’m looking at how to set up Flex Daily to accommodate this and its not readily apparent.
