Installed wireless flow meter successfully, now what?
@Parachi Once the Wireless Flow Meter is installed, paired and calibrated, you are now protected from High-Flow leaks and low flow problems. This week we will also be releasing in-active flow checks which look for stuck valves after your schedule or manual run.
If you scroll down on the Home or Zones screen, you will start to see actual usage instead of estimated. You can click into the Home screen view and see additional information around zone and day to day usage.
