PWS = the weather station outside so that is wireless.
Observer-IP box = box that wirelessly gets signal from PWS but must be wired into your home router.
Meteobridge = box that used to be a TP-link router but now solely exists to send weather data to various services. Can be wired or wirelessly connected to your home router. Can read observer-ip data.
Meteostick = USB stick that plugs directly into your meteobridge and allows the meteobridge itself to get the wireless signals directly from your PWS. You donāt need this if you are reading the observer-ip box but I had incorrect readings of the observer-ip every few days so I decided to invest in this and get rid of the observer-ip.
1.) Should both the Observer and the Meteobridge units each be plugged into an existing router. And theyāll be able to find eachother over the LAN and communicate?
OR
2.) the Observer should be connected via Ethernet directly to the Ethernet port on the meteobridge (TL-MR3020)?
So my WS-1400-IP went up today. Mounted to a wood privacy fence. Other than leveling it, I used a compass to point the solar panel SOUTH. What, if anything, should be done to ācalibrateā it?
Iāve essentially:
1.) plugged in the Observer IP into my router and updated its firmware to latest. Did not make any other settings changes to the Observer IP itself ā it remains set to defaults.
2.) updated my meteobridge for wunderground and PWSweather.com. Meteobridge appears to be getting the correct time, date, etc. from its servers.
Observer IP is actively communicating with the WS-1400-IP.
Meteobridge is getting data from the Observer IP.
Meteobridge is actively publishing current weather data for my weather station:
I too have confirmed Iām transmitting data to CWOP. Sent CWOP-Support an email confirming Iāve verified my location and data transmission. In the meantime, my PWS is available in PWSweather.com and Iāve selected it within the Rachio.
Once Iām accepted by CWOP, what do I need to change in the Rachio?
Thanks for all leg work, and sharing of that legwork boldblue737. I was having a hard time figuring out all the pieces but i now have everything set up and working. You helped a ton!
Confirming Iāve got CWOP setup and my PWS has been validated by NOAA/MADIS. Itās now an official station available in Rachio. Though it hasnāt rained in my area since I registered it, itās showing that no precipitation data is available (yet).
This still means the Rachio is taking advantage of all of my PWS data for use with its flex daily scheduling algorithm, correct?
Been monitoring my CWOP data online. Appears CWOP reports that my Ambient Weather WS-1400 PWS āSensor fails following checks: L3 Spatial Consistencyā
With the following additional info:
Average barometer error: 39.6 milliBars
Error standard deviation: 13.0 milliBars
Worst daily average barometer error: 44.0 milliBars
Is there anything I can do locally to correct this?
It absolutely POURED in our area today (weāre also under flood warning) and my WS-1400 weather station only reported 0.01 in. of rain??? What would cause this?
I canāt speak to inaccuracy regarding rainfall, my WS-1400 has worked perfectly in regards to that since day 1 but as for barometer error that is an EASY and necessary fix that ambient weather actually tells you to doā¦
If are using the observer-ip box to meteobridge link what you do is first go to major weather website like weather.com and look up the current barometric reading at the nearest airport to you (even small general aviation airport) and write down what the current value is. The go to your observer-ip control webpage and there is a tab that allows you to enter corrections to a whole host of data points, temp, wind direction, and barometric pressure. Look at what your system is reporting and enter the positive or negative number that would correct your pressure to the same as your local airport under pressure. This will instantly correct your data and it will remain perfect from then on, itās just part of the calibration process. Mine was way, way off out of the box but once I entered the calibration number to correct it to a nearby airport value it has been less than 0.01 millibar off for almost 2 months.
I do my correction in inches of mercury since thatās how we report it in the statesā¦ For example if my ws-1400 was showing 29.31 but the real value was 29.93 (as measured at a nearby airport) my correction value would be 0.62
