@bmb2109 - that is real easy and straight forward.
Be sure to run the existing Hunter system (e.g. one minute per zone) to make sure all the valves are working before starting on the migration.
The white Hunter common to any Rachio C port.
The Hunter PMV wire to the Rachio M port and activate the Master Valve setting in the Rachio app.
Hunter zone wires 1 - 6 to corresponding Rachio zones.
Hunter rain sensor one wire - doesn’t matter which one - to S1 and activate the Rain Sensor setting for that port in the Rachio App and the other wire in the 24 VAC - port. See ->
