Can you help me with connections to Change my hunter c pro to Rachio gen 3 ? I saw some forum topics but the wiring picture looks a bit different in each
Your sensor doesn’t look plugged in. Is that intentional? Also in your OG wiring, what is the bottom connection labeled? Under all the red wiring? Is there a black cable there?
Also did you tell the Rachio you have a MV?
Couple things. Looks like you PMV is a black wire. Check where you landed that thing - it’s not right on the Rachio. Zone 2 in your old setup had two wires on the terminal. That’s probably what threw you off.
Thank you ! That’s basically what I did wrong . I connected back one back to m in Rachio and it worked
