@MeterManSays has done a great job testing existing support for wired flow meters here:
Alas, there doesn’t appear to be a perfect / close match. My best recommendation is trying to use it as a Flowmec QS200-10 since that too has 0 offset. Issue is that the readings you will get will be 11.14 times lower than they should be, as in rachio will think the flow rate is 0.9 GPM instead of 10 as an example, but it may be enough to use the meter as a leak detection (can’t grantee).
