I installed my Gen 3 four days ago and in that time my controller has power cycled 3x (twice on the first day of installation and once yesterday). I assume the controller will power cycle for firmware updates but I am unsure as to how many are normal and at what point I should contact support. Thanks.
Have you tested the power supply. If you have another power supply with the same specs, you can switch them and see if the issue continue. If continue could be a controller HW issues.
I have been up since Friday noon and have had zero power related issues. So you might have an issue there.
It appears that this isn’t an isolated issue as the other thread shows. Could we all have power supply problems?
