Help with Zone settings and Schedules
These are the ones I got to do my catch cup tests
I know you can also use tuna cans if you have some of those laying around. The problem with just using one measuring cup is that you want to take several maeasurments around the zone so you would need to either run it several times as you move the cup through the zone or put down multiple cups.
