@sbillard, yes we would consider water over the saturation limit runoff. Sounds like the wood grass barrier is causing the water to pool. Is this installed for construction purposes?
@danckert, just curious, how long did you water before installing your Rachio? Are you attempting to water grass? Trees? etc?
Great tip!
@aristobrat, another great tip! Here’s a support article to learn more about moisture levels/graphs.
@Lars, what schedule type are you using? Flex daily schedules will have all weather intelligence features (including freeze delay) enabled.
