Hi guys, I am stuck at a new install, “We could not find your Rachio”. I am running an orbi network setup, 2.4/5Ghz. I am wondering if the problem is due to automatic network switching in the orbi. I looked through the forums, no love, only the PM’ed (private) answers (maybe I should go through tech support, but it is after hours here now). Downloaded Routethis, but that needs to be done via tech support as well, it looks like.
I used the orbi app to ensure both phone and rachio were on same network (2.4 GHz), and the rachio did get assigned an IP, showed up on network, but “We could not find your Rachio”.
Surely some of you have successfully set this up on an orbi network. Any tips? Been at this a few hours now, ready to ship it back…
OK I port forwarded port 53 (port forwarded, NOT port triggered, correct?), and created a static IP address for the rachio. Still no luck. Here is the current Routethis info: MXP48W7Q
It’s usually these complex and rule based networks that trip up the controller.
Is there any way to create a guest network that doesn’t have these restrictions for the controller?
When customers start to perform their own networking I need to bow out since I can’t see the whole picture versus a vanilla configuration and can’t help with troubleshooting. Our support@rachio.com might be able to help but it could take awhile before they can assist with detailed networking help.
I can’t offer solutions to your issues but I can tell you that I have an Orbi setup with 1 satellite, and had no trouble setting up the Rachio controller. Wish I was more tech savvy, but just wanted to assure you that, at least in some applications, the Orbi-Rachio combo is compatible. Good luck!
I called in to the support line, spoke with Meghan. We started from scratch, resetting and proceeding. My error was after 3 full bars, with the 4th flashing. She indicated that it would be a simple fix, related to firmware. Total phone time under 10 mins, wait time about 5 mins. Worked perfectly!
I too have an Orbi with one sat unit. I used the 5ghz radio and the default channel. I also paired it up to my Orbi before install to avoid range issues. Then when I installed it in the far corner of my garage, it started up fine.
Very interesting considering that the 3 can read both networks. I have an Orbi RBK33 and it connected without an issue however, I have a satellite 10ft away in my garage.
