Just when I think I know how to run this thing, another set of issues arrive.
Started it this year mid April and watering times were like 3-4 minutes a zone. I’m waiting for notices of weather / season adjustments like I got last year and its not happening. What has changed notice wise? Its getting warm, adjustments are needed.
I check history. the only runs recorded are my quick runs I did to keep my yard from dying.
I check schedule. “All Zones 2017” is on. Runs Mon, Wed, Fri . Should have run today. Did not according to history.
I check history again deeper. There are occasional power cycles, sometimes 2 or 3 a day. Power here is good. House is not losing power.
I didn’t recall a separate standby in addition to schedule enabling. I enabled the schedule which should kick standby off I think. Like when quick run disables standby. Oh well, it changes so much maybe this is a newer feature or something. The app is completely different this season.
How often do the schedule adjustments happen? I had one April 1. Didn’t see one for May and temps are 10+ degrees warmer now.
We adjust schedules (if opted in to seasonal adjustments) on the first of each month. When the controller is in standby I don’t believe we send a notification, but the schedule should be “correct” for that month.
Sorry to keep bugging you, but I don’t understand why I would have gotten notice for a schedule adjustment April 1, when I had no irrigation water and no schedule enabled, but not an adjustment on May 1. when a schedule was enabled. It seems standby would have been enabled both times as I didn’t open the app until around mid April. Was there an app update in April? Or maybe this is firmware related?
