I’m a new Rachio Gen 1 user and I have re-seeded a portion on my lawn. I would like to water these zones twice a day until they germinate and grow, however creating a fixed schedule (everyday, starting at 5:00am, with smart cycle and water budgeting turned off) seems to do nothing. When I press Run Schedule, it manually begins a sequence, but there is nothing showing on subsequent days.
A separate, all zone Flex schedule says it will not start for two weeks. What gives? Is there no way to force a fixed schedule? If so, this system is next to worthless… Help!
Yes, this is what I did, but no schedule appears in the calendar and nothing is scheduled to happen. I have tried multiple new fixed schedules, but none of them seem to “stick”
I have made new “Fixed Schedules” with Smart Cycle, Water Budgeting and Weather Intelligence turned off. Once I save the schedule; it doesn’t show up in either the calendar view or the individual zone tiles in the the “My Yard” display.
I would try to set up a schedule through the web app and see if that works. That will walk you through each step. Make sure you set it to every day. If you set up a fixed schedule it should stop those zones on the flex schedule when it sees the well full, so you will have to set two fixed schedules to run twice a day for those zones. Good luck and I hope this helps.
