Flow meter length feedback
@azdavidr, I assume he was looking for this fitting? I think it’s in high demand :wink:
@nmstough, the 6" of 1" pipe before the flow meter is needed to stabilize the water flow to avoid turbulence and inaccurate usage readings.
Regionally, pipe size and type vary. Same as indoor/outdoor installations for the controller.
We launched the product as a 1" flow meter and will reassess if other sizes are needed in the future.
We’ll update the install instructions to reflect this. From a cost perspective, it’s cheaper to use the 3 fittings than 4; pricing below:
3 fittings:
  1. 1 in. x 3/4 in. Brass Push-to-Connect Reducer Coupling x1 = $16
  2. 1 in. Brass Push-to-Connect PVC IPS x CTS Conversion Coupling x1 = $19
  3. 1 in. PVC IPS x 3/4 in. CTS Brass Push-to-Connect Ball Valve x1 = $25
TOTAL: $60
4 fittings:
  1. 1 in. x 3/4 in. Brass Push-to-Connect Reducer Coupling x2 = $32
  2. 1 in. Brass Push-to-Connect PVC IPS x CTS Conversion Coupling x2 = $38
TOTAL: $70
