Do these flow meters even work? My old one stopped working, never actually worked but at least it paired, then sent in for a replacement and this replacement won’t pair. I read another post about them not working after the last firmware update and that sounds about right. Right now I think you took our money and then dropped support for it because these things will NOT pair. They are freaking USELESS.
I had the engineering team send a different version of firmware that could help with the flow meter pairing.
Please let us know if that helps address your issue.
I have the same issue. I just bought a left over flow meter from local dealer and it also doesn’t pair with my controller. I have remove/inserted batteries 10s of time.
