Flex Schedule control via Home Assistant
The current algorithm for flex daily schedule durations uses the next day’s moisture forecast. These forecasts are notorious problematic for barrier island locations.
I have supported the request to remove these forecasts from the calculations and it’s my preferred solution. However, that depends on Rachio.
As an alternative, are moisture calculation parameters available via Home Assistant? If so, can I update durations via Home Assistant as well?
