Yes! Looks like you’ve got a few different valves in your box. Going to have to do some investigating to see which valve operates the zone that is leaking. Turn on each zone manually by turning the solenoid about a 1/4 turn. Once you find the valve just replace the guts of it…
You’ll also have a little bit of clean out to do of that box. Need to get all the excess dirt out of there before you unscrew the tops of the valves.
