I have a Rachio Gen 2 Smart Sprinkler Controller 8 zone unit installed and has been working like a charm and as expected.
But as of this year now that it is no longer raining, the controller will activate the valves. There are 4 valves connected to it. I have disconnected them cut back the wires a bit and reconnected back into the controller and have done the same for the valve wiring. I can use a toner and i get signal from the valve to the controller. I can open the valves manually so there is water.
So I have power to the valve from the controller and I have water flowing yet when i trigger the irrigation from the controller or from the app, the valve does not open. This is happening to all 4 zones.
Yes, common wire tones out. I testes all 4 solenoid wires and the common. As mentioned before, I rewire all 4 solenoids and teh controller as well before reaching out to you to avoid any silly questions on my part.
Can you provide photos of your setup? Also I know you’ve mentioned that you’ve used a toner to test the wire continuity, but have you tested actual AC voltage at the valves? It is possible that a partial break or short would provide enough connectivity for the tone to get through, but provide a high impedance obstruction for the power to get to your valves.
Can you please provide a photo of your setup? How do you have the valves wired into the terminal block of your Rachio? Have you tried moving common wire to a different C terminal?
